When transferring a mesh from a working study to a new study, with all the material properties, connections, fixtures and loads are the same, (magnitude of loads differ however), the new study won’t run or evaluate error message " Too much elements". How can the new duplicate study fail with error message too much elements where it worked on the original study? The method used to create new study is by going to simulation tab select study advisor - new study - linear static and then transferring all the loads, fixtures materials, mesh and connections manually by dragging and dropping the items from the original study to the next. Note that this doesn't always happen. Are we doing something wrong or is it a bug?
