Hello all,
I'm working on some enhancements to our templates and template cards, and have run into a hopefully simple issue. I have a template card that is used by two different templates, and was wondering if there is a way to get the menu string of the template that was run.
I'm dynamically populating some comboboxes (via EdmCmd_CardInput hook), and it would be helpful to be able to know which IEdmTemplate5 was called in order to make decisions on what to populate a certain combobox with.
Though it would solve my issue, I would like to avoid having to create two separate template cards.
Any insight would be much appreciated!
Kyle
Edit: EPDM 2012 SP2
That is an interesting question...I don't know if what you are looking for is possible...but why not just use two cards? You can make the second card from the first with a simple "Save As".
On an offshoot of your question. You've figured out how to change the values of a combo box at runtime? Please share!
