I'm curious if there's a way to export XML without running a part through a transition. Something that will push the XML output exactly as it does when you run it through a transition, so that it ends up in the same spot it usually does with the other XML outputs, but doesn't actually run the part through any workflow.
Got an answer from our reseller:
