I have several parts that I have created in an assembly and I want to take that assembly and re-save it as a new assembly and edit it. The issue I am having is that the parts are still link to the original assembly; so when change the height/length of a part the rest of the parts do not up date. So is there a way for me to unlink the parts from the old assembly but keep the references each part has to each other?
Thanks!
I want to avoid using a DT.
Thomas,
When you do the Pack and Go, you have the option to change file names as part of the operation. Double-click on a file in this column and it will bring up a dialog box where you can enter the new name. The file will be saved under this name and it will retain relations to the appropriate files in the new assembly.
