Just as the title states: When I open a flow model created in version 2011 SP5.0 using 2012 SP4.0, and go to edit the definition a boundary condition such as Env Pressure, the Faces box is empty. If I change anything, it forces me to select the faces before it will save. If I don't change anything, the faces are shown correctly when I left-click on the BC name in the design tree, and the simulation runs fine. Does anyone know of a fix or workaround?
unfortunately this is a known issue with 2012 SP4.0.
even if your file was brand new in 2012, if you edit the definition of an input, the faces will be lost.
I believe that I saw that it will be fixed with 2012 Sp5.0.
The only workaround is to X out of the edit definition command, that will keep your selections.
Please contact your reseller to report this issue and add your name to the SPR so that you are notified when it is resolved.
