How would I you about doing the Hem on this part in Section A-A? Is there an option to make it go back on itself? I did it using the extrude command but I would like to do it using Sheet Metal commands. Below is a pic of the part and I have attached the model I made as well.
Any help would be greatly appreciated!!
Chris
the approach i made assumes you encounter this scenario after the sheetmetal design is under way i.e. the base-flange has already been created.
the layout sketch has equations linked to it, so when you change the angle in the sketch, the hem and edge-flange will update automatically.
the layout sketch is not required.
