Hi
I am trying to simulate the motion of a ball through a hollow spiral,
but the ball doesn't touch spiral when released, it directly falls through the spiral instead of touching it. Please help me how to fix this problem
This is what I tried-
1) I used the 3d contact and applied gravity downwards, and positioned the ball at a certain distance above the cone, so that when simulation starts, the ball will fall into the cone and eventually roll down the helix.
2) The simulation ran peacefully (i.e., ball went down the spiral) when "Basic Motion" is turned on, in which I couldn't apply friction and co-efficient of restitution in between the bodies.
3) However, when I changed the mode to "Motion Analysis", using the same settings and gravity, the ball just fell straight down "through the spiral" as if it were not hindered by any thing.
4) When this didn't happen, I tried bouncing the ball on a rectangular sheet. Even then using motion analysis made the ball go through the sheet after bouncing few times.
Attached are the video and the solidworks file.
Thank you for your time.
You haven't told us what you did to try to solve the problem. After reading the Help topics, what changes did you make to the contact settings and what were the results? What solver(s) did you try and what setting adjustments did you try? Why wasn't the model attached?
When you post a question with no explaination of what you have done, with no model attached, it just makes it look like you have spent no time trying to learn the software and just want us to teach you. If you show that you have made an effort, you will tell us what problems to rule out and will usually allow us to go directly to the problem and get you a solution. If we have to guess what you have done, your post has a good chance of getting ignored.
