rephrase the bend radius question.
Question asked by Pete Peters on Aug 21, 2012
Latest reply on Aug 22, 2012 by Pete Peters
original discussion: https://forum.solidworks.com/message/310477#310477
Specs:
Rectangular Box
14G P&O Carbon Steel
40W x 24D x 25T
Top Die/ Punch Radius: 5/16
Measured 90 degree IR: 3/32
All 90 degree angles
Is this correct for a 40 inch OD measurement?
14G + 3/32 + 39.6631 + 3/32 + 14G
If this IS correct then you use the AS MEASURED IR for the SW Sheet Metal Parameters Bend Radius?
If this is NOT correct then am I using the Top Die/ Punch Radius: 5/16 for the SW Bend Radius?
This is a fundamental question but I've got a mental disconnect I need to get past here.
Thanks!
