Problam of Other Fitting Parts...
Question asked by Chun Hung Chen on Aug 20, 2012
Latest reply on Aug 20, 2012 by Peter De Vlieger
could any one use the part is build by self?
I just follw the Solidworks help to build the part , but couldn't be use on routing,
could any one have the solution to fix it?
the below is from SolidWorks Help.
You can create an axis in a fitting, such as a valve, to control the angular orientation of the fitting in a route sub-assembly. This axis must be named Vertical, and the axis must be perpendicular to the route passing through the fitting. When you insert the fitting into a route sub-assembly, the Vertical axis is aligned to the first construction line drawn in the 3D sketch at the insertion point.
