Has anyone seen where a single cutlist item in a weldment splits into two seperate lines in the cutlist in the drawing? In my case, even the patterned body is showing up as a different item number.
Any help would be greatly appreciated.
TIA,
Jason Lackey
If you do anything to a body that changes the geometry (even after it has been patterned) it will show as a seperate line. Solidworks is smart enough to know if the two bodies are identical though.
