I want to color select faces of parts in an assembly at the assembly level.
Thin brick wall with multiple copies of the same brick. I want to be able to make faces of the brick different colors in the assembly, without changing the part files.
I do not want to make each brick a different colro (this works) , only selected faces.
What happens is, If I set the color of one face, it changes for all instances of teh part, rather than om;y th eselcted faces.
If I set part color at the assemblyy level, I can set each brick to a different color, but only the whole brick, not selected sides.
Is this possible, I swear it used to be.
I've never been able to do it at the assembly level - need to add configs of the part with the different colors and vary the configs in the assembly
