hey...dear! i wanna make a mold of a gas turbine blade and i'm facing a problem here is that when i complete the flex twist and flex bend command and apply the parting line command the crazy split line coming out on the faces...yoy see in the picture.i have done max the flex accuracy but i'm still facing this problem.....please hlp me.
Flexing a part frequently results in bad surface geometry such as waves, wrinkles, etc. This is most likely why you are having the problem with the split, you created a wave/wrinkle in the part by forming it with the flex command. If you create the part as a sweep, loft, etc., you will most likely not have problems with waves/wrinkles in your surfaces.
