Hello;
I have a mate relation that has movement to allow for some rotation, of a lever. When i go down instead of the lever going down; it
shoots it up. I'm wondering if there's a way to allow for free rotation, but direct the clockwise movement instead of shooting it up c.clockwise.
Can you some how tell it to go down instead of up, even though it's possible with the constraints to go either way. I can't add another mate, or if will over constraint
it. Sorry if this is a bit foggy.
Thanks in advance for any help;
Rob_D SW 2012 sp4
Hello;
To add to my post I did find a work around. As the part was at 90 degrees, it allowed it to freely shoot up or down, it went up. But
when i made it's start postion at 90.01, just slightly down;, it was enough to cause the free path, to tend toward down or clockwise, instead of up. Also I should of said that the rotated part is attached through a linkage, to a part that just goes staight up & down.
Regards,
Rob_D
