I receive an error in sheet metal parts " The radius of the bend fell outside of the bend allowance/deduction table, K factor will be used instead". Has anybody ever encountered this? and how can this be fixed?
Thanks in advance
Thanks in advance
We are also having this issue, could you please take a look at our Bend Table and let me know if there is anything wrong with it?
Many thanks,
I just read on another post that the table should be in decending gage order, or thinner materials first.
Hi Bernie,
The table is currently presented in that order, I am just re-creating our table to see if there was just an odd glitch created.
I initially had the table in thick to thin order, then went in and switched it around, then the problem arose.
Note:
Just tried the re-created table, problem still exists.
This is also in SolidWorks 2013 I should add...
It usually occurs when doing an edge flange, after I flatten and unflatten the model.
