1 Reply Latest reply on Aug 9, 2012 5:55 PM by Don Cheke
    Spell Checker Conflict
    Don Cheke
      I just installed WinZip v16 and WinZip Courier and now when I try to use my SolidWorks spell checker I get a couple errors. See attached images. Does anyone know of a fix?
      This is the details:
      Detailed technical information follows:
      (Inner Exception)
      Date and Time:         09/08/2012 3:20:25 PM
      Machine Name:          DONCHEKE-PC
      IP Address:            fe80::b8ec:2fdd:48f0:9976%10
      Current User:          DonCheke-PC\Don Cheke
      Application Domain:    C:\Program Files (x86)\WinZip Courier\
      Assembly Codebase:     file:///C:/Program Files (x86)/WinZip Courier/AddinExpress.MSO.2005.DLL
      Assembly Full Name:    AddinExpress.MSO.2005, Version=6.5.3057.2005, Culture=neutral, PublicKeyToken=4416dd98f0861965
      Assembly Version:      6.5.3057.2005
      Exception Source:
      Exception Type:        System.ArgumentException
      Exception Message:     The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
      Exception Target Site: Object reference not set to an instance of an object.
      ---- Stack Trace ----
      (Outer Exception)
      Exception Source:      mscorlib
      Exception Type:        System.Reflection.TargetInvocationException
      Exception Message:     Exception has been thrown by the target of an invocation.
      Exception Target Site: InvokeDispMethod
         System.RuntimeType.InvokeDispMethod(name As String, invokeAttr As BindingFlags, target As Object, args As Object[], byrefModifiers As Boolean[], culture As Int32, namedParameters As String[])
             AddinExpress.MSO.2005.DLL: N 00000 (0x0) JIT
         System.RuntimeType.InvokeMember(name As String, bindingFlags As BindingFlags, binder As Binder, target As Object, providedArgs As Object[], modifiers As ParameterModifier[], culture As CultureInfo, namedParams As String[])
             AddinExpress.MSO.2005.DLL: N 0488 (0x1E8) IL
         System.Type.InvokeMember(name As String, invokeAttr As BindingFlags, binder As Binder, target As Object, args As Object[])
             AddinExpress.MSO.2005.DLL: N 0000 (0x0) IL
         AddinExpress.MSO.ADXAddinModule.GetRibbonControlEnabled(idMso As String)
             AddinExpress.MSO.2005.DLL: N 0042 (0x2A) IL
