Hi.
I have a mold and I want to make a sample from that this mold should make. How to do this?
Regards
Hi.
Regards
Pablo,
Sorry, your question is not very clear.
Are you trying to design a mold for a sample part?
If you are looking for help on how to design the mold, there are helpful discussions here
Use the mold and make the part...........
Yyou could apply a mold release to the two mold parts and use an epoxy or silicon to fill the cavity and have a part that way.......but if you dont get a clean release of the epoxy you will end up with mold parts that need to be cleaned or worse stuck together, silicon will be soft, but easy to get out of the mold
Welcome to SolidWorks forums Pablo.
Offset the inner surface of the mold area by 0 distance. Then you can knit all the surfaces. Modify as required.
OR
Extrude a block without merging into the mold. Then subtract the bodies to get the inside part. Modify as required.
Please use "advanced editor" in case you want to attach any files.
You might also find this post helpful for your future reference
