MLMattias Lokgaard08/08/2012
Hi
I have a macro running on a BOM table, when I run the macro on small assemblies it works with no problems. But as soon as I have a large assembly (over 50 parts) solidworks stop working and has to be terminated (no error message, just a window popping up saying "Close program" or "Look for solutions on the web"). I am using a Component2 command (ComponentReference). It dies as soon as I enter the Else statement below.. I would appriciate all the help I could get, thanks once again! I am using SW 2012 sp4
Dim swBomTbl As SldWorks.BomTableAnnotation
Dim swBalloonOpt As SldWorks.BalloonOptions
Dim TableAnnotation As SldWorks.TableAnnotation
Dim DrawComponent As SldWorks.DrawingComponent
Dim SelMgr, objApp As Object
Dim I As Long
Dim NumOfObj, SelObjType As Long
Set swModel = swApp.ActiveDoc
Set SelMgr = swModel.SelectionManager
NumOfObj = SelMgr.GetSelectedObjectCount
Debug.Print "Number of selected Objects: " & NumOfObj
For I = 1 To NumOfObj
SelObjType = SelMgr.GetSelectedObjectType2(I)
Debug.Print "Type of object selected: " & SelObjType
    Select Case SelObjType
        Case 98
        Set swBomTbl = SelMgr.GetSelectedObject5(I)
        Set TableAnnotation = SelMgr.GetSelectedObject5(I)
        Debug.Print "BOM Table Selected"
        Case 12
'        DrawComponent = SelMgr.GetSelectedObject5(I)
        Debug.Print "Drawing View Selected"
    End Select
Next I
CompRef swBomTbl, TableAnnotation
'AddBalloon DrawComponent
swModel.ForceRebuild3 True
Sub CompRef(swBomTbl As SldWorks.BomTableAnnotation, TableAnnotation As SldWorks.TableAnnotation)
Dim Row As Long
Dim WRow As Long
Dim K As Long
Dim MergedCell As Boolean
Dim RowCount, CompCount, ColCount As Long
Dim Component As Component2
Dim CellText As String
RowCount = TableAnnotation.TotalRowCount
ColCount = TableAnnotation.TotalColumnCount
For K = 2 To RowCount - 1
    Debug.Print K
    Row = K
    WRow = K
    MergedCell = TableAnnotation.IsCellMerged(Row, 0, WRow, ColCount - 1)
    Debug.Print MergedCell
    If MergedCell Then
    Else
        CompCount = swBomTbl.GetComponentsCount(K)
        Set Component = swBomTbl.IGetComponents(K, CompCount)
        CellText = TableAnnotation.Text(K, 0)
        Select Case CellText
            Case "--"
                MsgBox "Unable to find BOM No. at Row: " & (K + 1)
            Case ""
                TableAnnotation.DeleteRow (K)
            Case Else
                Component.ComponentReference = CellText
        End Select
Next K
//Mattias
