Saving and using sketch blocks?
Question asked by Amber Brooks on Aug 3, 2012
I created a sketch block of a set of cuts I want to use often.
When I create the sketch block from a current sketch it deletes the dims from the current sketch so it is undefined. Then I get out of the sketch and save the sketch block as a file in My Documents so I can use it later. Then I hit the undo butto to restore the dims to the sketch I copied from. This seems like a very crazy way to create a sketch block. The help files and other posts I've found so far do not refer to any of this.
How do I create a sketch block the easy way where I dont have to go through all the hoops listed above?
Can I reate a sketch block with the dims saved from the copied sketch?
Also, when I explode the sketch so I can move some of the cuts it blows up and goes all over the part. Any ideas what this happens?
Thanks.
I'm using solidworks 2011.
