Hi every one
I started working with DriveWorks, and i have a problem with the weld thickness.
I have a welded assembly, when I change the plate thickness the weld must change too.
For exemple:
if the plate is 1/4", the weld must to be 1/4"
if I change the plate to 3/8", automatically the weld must to be 3/8".
I need this because I have a lot of welded assembly, and if I need to change one by one, I'll lost many time.
With DriveWorks is the same the Design Table, I made many rules but I can't select the weld thickness to insert a new rule to it.
I don't know how to link the thickness weld to thickness plate.
