1 Reply Latest reply on Aug 5, 2012 1:33 PM by Jerry Steiger
    Rotate by Delta XYZ doesn't rotate by the correct amount
    Dmitry Ponomarev
      I need to rotate a part in my assembly exactly 45 degrees and I have it properly constrained (cylindrical)
      Now I use "Rotate Component" and I enter 45 degrees.
      When I do smart dimension between two previosuly parallel faces, it shows 39.34.. degrees
      Initially I thought this rotated by Z in the viewport plane and not about the real Z-axis, but when I tried again with from the top down view, the rotation was incorrect again
      Why is this happening? This seems like a major bug
      This is solidworks 2012
