Instead it moves my arc. Or maybe it's changing the radius AND moving the endpoints?
Is there a trick to dragging the arc radius without moving the endpoints of the arc and not giving it a radius dimension or fixing the endpoints?
It works as expected when first creating the 3-point arc. But when I try to edit it, dragging moves it instead.
It would be nice if the endpoints didn't move unless I pick them and drag. Something doesn't seem right.
Are you dragging the center point or the arc itself? It should be that dragging the center moves the arc and dragging the arc changes the radius. Atleast that's how mine works.
Lachlan
