I have a question please. In solidworks flow analysis whe you run particle tracking study what is exact unit setting of the mass flow rate. for example presume sand with 0.4mm diameter. in that case what will be best setting
0.1kg/s, 0.01kg/s 0.001kg/s or 0.0001kg/s etc. What is your suggestion please dear experts. Thank you
I have never investigated this, but I believe that this only matters if you use the mass erosion or accumulation data available. Where the particles go is based on their diameter and material properties (i.e. momentum & gravity), so how many particles are there doesn't affect it as SW does not look at particles hitting each other, only solid surfaces.
