I have a sketch of intersecting contours, it's an arrangement of overlapping squares, is there a quick way I can trim all the intersecting segments and/or select the entire sketch to extrude? As of now, I can't extrude the whole sketch because of the intersecting segments.
Juan
Hi Juan,
Exit the sketch your in, set the sketch to visible and start a new sketch on the same plane.
Use the Convert entities tool to pick the contours you need for the extrusion.
Adrian.
