I have been having trouble converting files from different formats into Solidworks (ProE,Step,Iges, etc.). I really need somebody to help me, explaining what I have to do in order to convert to sheetmetal correctly. I have attached a ProE part that I was playing for hours and even try to save into Step/Iges, then bring into Solidwork (still not working). Please help,Thank You.
Jeff
This is one of worst models I have seen in a long time. If you can't send it back to the customer and get them to remodel it properly then I would get all the dimensions from the part and redraw as a sheet metal solid model with corner relief. It should be a fairly straight forward part. There has been a number of times I would get a part from a customer and then have to turn around and remodel it so I could work with it.
