I made a cylindrical array of spheres that I need to save as an STL file but every time I try to save it I get a message that says something like 'there are too many triangles for the file to be saved safely, please lower the resolution.' I changed the display resolution, but it does not affect the file resolution when saving, any help will be greatly appreciated.
Juan
When doing your Save As and after selecting STL for Save As Type there is an Options button in the save as dialog box. Select that and lower the resolution of your file there.
If you are doing that already, considier breaking your array into several smaller files, and combine in the software you are bringing the STL into.
Cheers,
Anna
