I'm trying to use the ePDM BOM function to export an excel file. However, not all my data is visible. All parts have Description variables, and my Library part's Descriptions are not showing in the BOM Description column. Or should I say, most of the library components variables are not showing, at the upper lever assy. If I view a lower level assy, then the same part variable may now show.
Is there a setting somewhere that will only show item variables at certain structure levels (sub-assy levels)?
I've looked into, part states, config properties, folders in the assy structures, and more and just can't seem to figure this one out... I'm simply trying to create a BOM using the ePDM tool, and I'm ready to just make a fake drawing & export a BOM from a table... I know this tool should work, I'm just not using it correctly.
Thanks in advance!
Check the configurations used in the assembly. If the config used by the assembly doesn't have a description (or other variable) it wont' show in the BOM file.
Add <configuration> as a column.
