Hi , I am fairly new to design for injection molding. I was never taught any 3D CAD at my school and just learned on my own. I wanted to hear from experienced users what their workflow is like when designing plastic parts. I have found that it is critical to have draft in your design but at the same time have had a really tough time designing with it. Simple parts (say a rectangular plastic box with features, ribs, etc) that were easy to deal with become complex if extruding with draft. For me its hard do dimension things when there are no orthogonal surfaces and everything is at an angle? Is it common practice to choose "draft" in the extruded boss/base or extruded cut windows? Or is it best to just model your part and add draft at the end? I am full of questions about the plastic part design process but dont want to overwhelm users so the draft questions will suffice for now.
thank you
Hi Everyone, I just ran across the DraftXpert tool, wow! that solved all my problems. I was able to go in and cahnge all that green inside to red . Im still trying to work out how it decides to add negative or positive draft, but with a little trial and error I was able to correct all the drafts on the part above. Thanks to everyone that took the time to answer, I will now be adding draft as I go like you guys sugested and then fix the inverted draft caused by the shell command with DraftXpert.
Alan
