I tried to write a code in vb for creating new line style
but it is not working
Solidworks does not create line other than formatting key A or B
def = "B,1.2,-0.2,2,-0.1,2" or
def = "A,1.2,-0.2,2,-0.1,2"
I want to create line style as below
-----o------o------o-----o------o
Pls guide me for the same
-Sanjay
example in api help given as below - I tried with this example but I am unable to acieve the new line style I want
Dim def As String
Dim name As String
Set Part = swApp.NewDocument("<SolidWorks_install_dir>\data\Templates\drawing.drwdot", 2, 0.2794, 0.4318)
swApp.ActivateDoc2 "Draw1 - Sheet1", False, longstatus
printData "Line Style Data at Start", ""
name = "NewOne"
boolstatus = Part.AddLineStyle(name, def)
printData "Line Style Data After Add", ""
Dim names As Variant
Dim styleNames(2) As String
styleNames(0) = "NewOne"
styleNames(1) = "CHAIN"
styleNames(2) = "PHANTOM"
names = styleNames
' Save line styles, replacing already saved line styles
boolstatus = Part.SaveLineStyles("c:\temp\styles", names, True)
printData "Line Style Data saved to file ", "c:\temp\styles"
' Delete a line style
boolstatus = Part.DeleteLineStyle("NewOne", "STITCH")
printData "Line Style Data After Delete", ""
' Load saved line styles, replacing existing line styles
boolstatus = Part.LoadLineStyles("c:\temp\styles", names, True)
printData "Line Style Data Imported from file", ""
Sub printData(title As String, file As String)
Dim types As Variant
Dim i As Integer
Dim stat As Boolean
Debug.Print Chr$(10) + "-------------------------"
Debug.Print title
Debug.Print "-------------------------"
If file = "" Then
stat = Part.GetLineStyles(names, types)
Else
stat = swApp.GetLineStyles(file, names, types)
If stat Then
For i = 0 To UBound(types)
Debug.Print Str$(i) + " ", names(i) + " " + types(i)
Next i
Else
MsgBox "Error in printData"
