I am currently trying to figure out how to remove a bend from a base flange (Original design called for 3 line segments with one bend). When I remove the angle and make the line horizontal the entire part blows up and give the error "No bends found". Is it possible to remove a bend without errors? See simplified part example. Remove angle and set to horizontal or colinear and exit sketch. Thanks in advance for your time!
Chris,
I made your line segments collinear and then deleted the points between them, it flattened OK. I noticed that there is a split point coincident with the origin which also needs to be removed. I don't know if this will work for your real part but it works for the sample.
Erik,
