RSRichard Sonnier19/07/2012
When I export to .DXF from Soliworks my curves are being converted to a series of short line segments. I am trying to create a program to cut out text for a sign using CNC Plasma cutter. The only file type the machine accepts is DXF. The line segments show up on the cut metal and make for a really ugly cut. I need to find a way to keep my smooth edges whenconverting.
Here is my method for creating the text:
I create sketches using sketch text function.
I dissolve the text into sketch segments (at thispoint the curves are still curves)
Then I export to .DXF with the following options:
        Version: R 2000-2002
        Fonts: AutoCAD Standard only
        line Styles: autoCAD StandardStyles
End Point merging: enable Merging checked
High Quality: High Quality DWG checked
