Does anyone know if it is possible to have bend lines show on a drawing of a freeform bend (Lofted Bend)? I have done the following:
- Right-clicked on the Flat-Pattern -> Edit Feature -> unchecked Merge Faces, then checked it back = No bend lines on drawing
- Document Properties -> Sheetmetal -> all checked = No bend lines on drawing
Is it because I am using lofted bend? I have done lofted bend before and always gotten bend lines before. I have also done a hard shutdown of PC to clear cache, and still no lines.
I am using SW2012, SP03. File I am working on is attached.
Steve Zema
See item #7 in lofted bends, this can only be set at the time you are creating the loft.
