I am facing a problem with read only files. When ever I open some assembly it says that some one is using this file. But at that time no one is using that file.
so now I can not update that file. I have deleted all temporary file from my PC. I keep all files on server.
Can anyone help me out.
Welcome to SolidWorks forums Piyush.
Go to window explorer and right click on the file and select properties. Now check if it is set to read only or not. If yes then uncheck read only and open the files in SW to see if you get same message.
Other thing might be that if you're using PDM and you don't have the ownership of the file (and PDM is checked under Tools> Add-Ins), then you might also get this message. If yes then uncheck PDM from tools > add-ins and check.
Got to Tools > Options and click External References and uncheck Open referenced documents with read-only access
If above don't solve the issue, then please upload one sample file here to check.
Please use "advanced editor" in case you want to attach any files.
You might also find this post helpful for your future reference
