I am making cable routing for my assembly. I found it very disturbing that my assembly is always turning transparent during routing. I am sure there is an option which make it possible that even editing or creating a route won't turn assembly transparent. I just haven't found that option. Now I would need your help to locate that option.
Thank you
this is not particular for routing.
this is a general behaviour . when working with assemblies when you enter the edit component mode the default is to force all components around it to be transparent.
you can change this by changing the option in tool--optons--display selection
change "Assembly transparency for in context edit" to maintain transparency or to opaque
Controls the transparency options when you edit assembly components. These settings affect only the components that are not being edited. (This option is not available when Large Assembly Mode is on.)
