2 Replies Latest reply on Jul 15, 2012 9:48 AM by Kelvin Lamport
    What's the point of using "Simple Hole"?
    Eduard Bardaji
      Hi All,
      I thought that selecting "Hole Wizard Profiles" or "Hole Callout" would produce different results in drawings when inserting hole dimensions with "Model Items...". However, these only produce different effects if a hole feature is inserted via the "Hole Wizard" function, not the "Simple Hole" function. Then what is the point of performing a hole with the "Simple Hole" feature rather than "Extruded Cut"ing a sketch w/ a circle?
      Thanks!
