I am attempting to use the same part multiple times within an assembly to identify other parts. I have it set up where there is extruded text on an identification plate. I would like to use the same ID plate in the assembly, but alter the extruded text to identify multiple parts.
Am I able to create a configuration for each part number on the plate (have different configurations for each part number)?
Thank you
I have done this when sketching by linking the text to the configuration name so this way when you change configurations of the part the text will update. Take a look at what i have attached. There is a picture to show how to link the text to cofig name and a part that is using this technique.
