I'm bumbling through learning the electrical routing. Can someone tell me why when I get a cable/wire routed, it only shows the sketch line? I don't see anything anywhere that shows how to "turn on" the wires. It shows the wires in the preview, but not in the assembly. I even did a test render in 360 to see if they would show up there. They didn't.
There are thousands of other questions, but I'll keep it simple.
Derek
Going on memeory here from when I went thru the routing tutorials. Routing is creating a sweep for each wire; check your route sketch to see if it has a bend that is too sharp.
