0 Replies Latest reply on Jul 9, 2012 3:51 PM by Kevin Hogan
    Configuration Publisher Problems
    Kevin Hogan
      Im trying to set up a publisher with a mulit variable design table assembly.
      I can get the first part down, where I can select between two different pipe diameters.
      But when I go to the second part to be able to select the pipe length, I only get one pull down option activated. The second one is just listed with no way to select the different part variable.
      Any ideas on how to get it to where they are activated when i have the correct pipe dia. selected?
      Also Im still using 2011.
      Thanks in Advance
      Kevin
