I have a complete data about the helical bevel gear (Skew bevel gear), but i can not make tooth profile in solid works
Can any one guide me to model a tooth?
pl find the details of gear & pinion below
Number of teeth Pinion / Gear = 16 / 52
Angle of shaft axes = 30 [°]
Pressure angle = 20.0 [°]
Base helix angle = 30.0 [°]
Direction of teeth (pinion) = right
Face width = 5"
Diametral Pitch transverse (outer, midle, inner)= 2.1502 / 2.3397"
Diametral Pitch (outer, midle, inner) = 2.4828 / 2.7017"
Transverse module (outer, midle, inner) = 0.4651 / 0.4274 [in]
Normal module (outer, midle, inner) = 0.4028 / 0.3701 [in]
Pitch cone angle d 6.9262 / 23.0738 [°]
Tip diameter (outer) = 9.4662 / 26.6762 [in]
Tip diameter (midle) = 8.7566 / 24.6767 [in]
Tip diameter (inner) = 8.0471 22 /.6772 [in]
Pitch diameter (outer)= 8.0442 / 26.1438 [in]
Pitch diameter (midle)=7.4413 / 24.1842 [in]
Pitch diameter (inner)=6.8383 / 22.2246 [in]
Root diameter (outer) = 7.2701 / 24.6410 [in]
Root diameter (midle)= 6.7252 / 22.7940 [in]
Thanks in advance!!!
