Hi. When I try to load the results from a flow analysis (temperature and convection) into a thermal simulation, the results that show up are all zero. However, when I look at the results in the flow simulation they look reasonable. I have noticed that the iteration that is loaded into the thermal simulation is always one higher than the number of iterations in the flow simulation (e.g. if the flow simulation took 90 iterations the results that are loaded into the thermal simulation as a boundary condition are marked 91). I'm doing something wrong but just can't see what. Any help is appreciated.
