I have an Engines Intake and setup an excel file to show the pressure changes(attached)
Time-Dependent is enabled, Under Calculation Control Options, In the "Finish" Tab Only Maximum Physical time of (0.01412s) and Goal Convergence are selected. Also In "savings" Tab we have save before refindement and Periodic saving checked. Set as Physical Time and with a period of 0.000114s
When we right click flow trajectories and click animate, all we get is one cylinder getting air, its not showing us a time based flow trajectories with each cylinder getting air based on the table.
Also we enabled "time info" under Flow Simulation and Time = 0.01412s, pretty much its only showing us the last frame?
So then we viewed The Help file which talks about the "Animation Wizard", 10 Sec video Next> Next > selected sanerio based animation Next> Uniform Distrubution Start from 0 and finish at 0.01412s and Finish.
I hit play it starts playing I can see under "Time =" is changing but there are no flow trajectories?
It is quite simple. You just forgot to do one thing: when you finish with the wizard, you have to put your cursor in the "timeline" and in front of the "flow trajectories", right click, "insert control point" and then extend it for 10second.
You then should be able to see your animation by playing it!
