Hello All,
I was wondering what happened to the sheet metal function? When I was working in SW2011, I could create a loften bend of a 30 ft piece of sheet metal that has a high end of 2.75" and a low end of 1.375", the I could apply Sheet Metal > Extrude Cut and sketch where 1/8" weld gaps would be and cut them, then I would have kept all bodies and have a multi-bodied part with individual flat patterns. NOw in SW 2012/SP04, that function doesn't work well, stating that my part needs to be a sheet metal part. The cuts were made in two ways: a planar cut while still in bend state and surface cut in the unfold state, for which I would get the message when I tried to fold it back.
Does anyone have another option to achieve this, beside using multiple lofted bends?
Steve Zema
Make sure you've the option "Create multiple flat patterns whenever a feature creates multiple sheet metal bodies" selected under Tools > Options > Document Properties > Sheet Metal
And then you'll have to delete the cut feature and add it again to get multi body flat pattern.
