2 Replies Latest reply on Jul 2, 2012 8:15 AM by Pascal Bigot
    mohr coulomb criteria?
    Pascal Bigot
      Good morning
      I need for an analysis to use the Mohr Coulomb criteria.
      I tried to use it on a simple case: a torque applied to a rod
      I mesh and run a static analysis. And then I visualyse the criteria value of the center area
      (The material use to calculate the criteria has the following properties: ultimate tensile strenght: 20MPa , ultimate compressive strenght:690MPa)
      Firsly  I visualise the Von Mises security criteria distribution:
      The result is coherent as it show an high coefficient in the center of the rod which decrease when we go to the periphery of the rod.
      Secondly , I visualise the Mohr coulomb criteria distribution:
      I can't explain the result! according to me this doesn't have any sense?!
      Is there a bug in solidworks?
      Can somebody help me?
        • Re: mohr coulomb criteria?
          Dave Laban
          Which version of SW are you using?  We found a critical issue with the mesher in SW11 SP5 (see https://forum.solidworks.com/message/250006 ) that threw out unusable results, it may be you are seeing a result of the same problem in a different way?
            Pascal Bigot
            Dave thank you very much for your answer.
            I have got SW12 x64 SP4.0.
            I have a look at the post you indecated to me.
            however I don't think this is the same problem. I have made several trials with different models and different meshes and for each ones the results is not what we could expect.
            futhermore the other graph (VonMises strain, displacement, P1,P2,P3 , etc) seems to be correct. Then it should indicate that this is not a mesh problem
            I thinks the formula of Mohr Coulomb criteria, is not well calculated.
            I have extract in excel the P1 en P3 values for the nodes located at one end of the rode (the shape is a disk). Following the solidworks equation, I have calculated the Mohr coulomb criteria. As i have the coordonnates of the nodes, I have also calculated the distance of each node from the center of the rod (ie. the radius).
            I draw the Mohr Coulomb criteria against the radius:
            like expected, the M-C criteria is proportional to the radius. SW don't show the same result!
            This indicate that SW calculated well P1 and P3 but that the calcul of Mohr-Coulomb criteria is wrong?
