Hi all,
I am wondering if it is possible to have the Cut List description in my BOM description? I am working on automating the BOM of steel structures and it would be awesome if was possible, I know that you can insert the Cut List description by choosing "Indented" in the Bill of Materials property, but the problem is that I will get two rows instead of one and then multiple length values. (See attached pic.) I cannot use the Weldment Cut List, because I have a lot of different equations linked to the BOM thru the Custom Properties and would be glad not to touch them. Because it is not possible to make a Cut-list template, right? I hope you guys could give me some input on this one, it would help me a lot. If you don't have a solution, post your idea! I am open to any suggestions!
Thanks in advance
//Mattias
Any one? I haven't solved it yet and I would appriciate all the help I could get.. I realized that the Cut List description comes from the description in the SLDLFP file, (the library file from the weldments). But how would I point the custom properties description to get the information from that SLDLFP?
Regards
Mattias
