I am working with a scan .stl file (Surface scan) and try to convert in to model using Scanto3D tool (2011). The problems I am facing: I could not able to see the measurements and the mass properties got disabled. My intention is to compute the volume of the scan object. I understood that we need to make a watertight model. I am not a profesional of Solidworks. Please suggest what could be the reasons that mass properties do not appearing. The same I can see when I open same .stl in Meshlab.
Hi - if all you need is the volume of an STL body, Netfabb Studio Basic (free download from netfabb.com) gives the volume, area, etc. Doing this in Solidworks from an STL is going to be hard work, as the Scanto3D tool needs a lot of work on complex surfaces to produce a watertight model.
