I want to save some assemblies we have of supplier parts such as valves which have a lot of parts in the actuator that are hidden from view.
I want to make these a lot simpler to speed up large assembly opening times.
I have done this before many time but I am always unhappy with all the gaps and faulty faces this produces, I usually fix these in the import diagnostics, is there a better way, as this does not always resolve all of the faults and I am still left with the blue highlight to the edge of faulty geometry.
What I am really asking is the best way to repair the gaps and faulty faces???
Thanks.
If you save as from assembly you can save as a .sldprt go into options and this will give you a variety of settings including saving a external surfaces, external bodies, or all bodies. I generally go for all bodies and delete the ones I don't want myself.
