SW2011
I see in the Hole Wizard under Hole Type that there is a sixth choice for creating a custom hole size. It appears that I need to use a custom hole size to make a hole for a countersunk 120 degree 1/8" rivets (SK42BS). I am setting the Type to be Countersink and then enter the dimension as: 3.25mm diameter, 2mm depth, 120deg C-Sink Angle, and 5.58 C-Sink diameter.
That works. What can I do to save this setting so that I can select that type of hole again on other parts?
The sixth choice is for legacy holes, but either way you can save out hole wizard holes that you modify or want to reuse. The button circled in red will allow you to save out any holes that you use, and the button circled in green will allow you to load the favorite when you want to use it again.
-Rohit
Online SolidWorks Training: Solidwize
