My company has just started using 3DVIA Composer 2013 and my co-worker and i had completed one of the composer classes, but i have run into a question on the capabilities of the technical illustrator (specifically) with the BOM table. is there a way to coincide the actors and their selection in the BOM table with hyperlinks, allowing you to use the illustrator as a diagram that links to an even more specific page for the Part selected. And if there is a way to do this can it please be shown here or explained here step by step, because i will end up using this a LOT.
I have found out that if you actually link put a link on the part itself and then go into the TI, if you click the part/actor, the callout or its spot on the BOM table it follows the link completely because they becoem a part of the same Parent/child relation in a sense.
