CRCesar Rivera26/06/2012
I am working on a figure which has a mathematical shape.
I coded on MatLab the points in the xyz cordinate.
I saved the file as .xyz format to be able to open it on SolidWorks as point cloud.
I successfuly open the file but I want to make it solid. I make the surface first by using the option Mesh Prep Wizard then I tried using the Surface Wizard option (Automatic and Guided) but neather of them worked.
With the Automatic it develops some kind of a mesh but it looses acuracy on the edges and the surface.
With the Guided I tried with each reference plane individualy but it didn' work.
I also tried using the Curve Wizard but the curves that it develop at the edges of the part are not that accurate with the edges.
I even try using the Knit option but it needs more than one surface to use as a reference, but it doesn't recognize my mesh as a single surface nither as a combination of surfaces.
I think there should be a easier way to develop a solid structure having a enclosed figure.
