The issue I am having is that I am trying to apply an external force to a very complex part with alot of scar marks in it. The issue is when i go to select the surfaces my machine very quickly becomes incredibly bogged down. There is no way i can make it through selecting all the individual surfaces at this rate...
What I am worndering is if there is any easier way to select the surfaces you are trying to apply force to? There must be some way I can select all the surfaces in tangency or something?
Not ideal, but would having multiple force loads with fewer faces in each be possible? So say instead of having 1 force load on 100 faces, have 10 separate forces but only applied to 10 faces at a time?
Hiding the arrow symbols also does a good job of speeding up things if you hadn't already tried that.
