0 Replies Latest reply on Jun 25, 2012 1:52 PM by Unspecified Unspecified
    DraftSight view problems
      Hi all,
      I've got this problem with DraftSight, that when I open any dwg file (see attached mechanical.dwg) I can only see strangely shaped lines (see attached screenshot - mechanical_draftsight.png).
      When I do the export to pdf and open that pdf file, the drawing looks correct (see attached mechanical.pdf).
      DraftSight version is V1R2.
      Here is some system info:
      linux toor # emerge --info
      Portage 2.1.10.65 (default/linux/amd64/10.0, gcc-4.5.3, glibc-2.14.1-r3, 3.2.12-gentoo x86_64)
      System uname: Linux-3.2.12-gentoo-x86_64-Intel-R-_Core-TM-_i5_CPU_M_480_@_2.67GHz-with-gentoo-2.1
      Timestamp of tree: Mon, 25 Jun 2012 16:30:01 +0000
      app-shells/bash:          4.2_p20
      dev-java/java-config:     2.1.11-r3
      dev-lang/python:          2.7.3-r2, 3.2.3
      dev-util/cmake:           2.8.7-r5
      dev-util/pkgconfig:       0.26
      sys-apps/baselayout:      2.1-r1
      sys-apps/openrc:          0.9.8.4
      sys-apps/sandbox:         2.5
      sys-devel/autoconf:       2.13, 2.68
      sys-devel/automake:       1.9.6-r3, 1.10.3, 1.11.1
      sys-devel/binutils:       2.21.1-r1
      sys-devel/gcc:            4.5.3-r2
      sys-devel/gcc-config:     1.6
      sys-devel/libtool:        2.4-r1
      sys-devel/make:           3.82-r1
      sys-kernel/linux-headers: 3.1 (virtual/os-headers)
      sys-libs/glibc:           2.14.1-r3
      Repositories: gentoo
      ACCEPT_KEYWORDS="amd64"
      ACCEPT_LICENSE="*"
      CBUILD="x86_64-pc-linux-gnu"
      CFLAGS="-O2 -pipe"
      CHOST="x86_64-pc-linux-gnu"
      CONFIG_PROTECT="/etc /usr/share/config /usr/share/gnupg/qualified.txt /usr/share/maven-bin-2.2/conf"
      CONFIG_PROTECT_MASK="/etc/ca-certificates.conf /etc/dconf /etc/env.d /etc/env.d/java/ /etc/fonts/fonts.conf /etc/gconf /etc/gentoo-release /etc/php/apache2-php5.3/ext-active/ /etc/php/cgi-php5.3/ext-active/ /etc/php/cli-php5.3/ext-active/ /etc/revdep-rebuild /etc/sandbox.d /etc/terminfo"
      CXXFLAGS="-O2 -pipe"
      DISTDIR="/usr/portage/distfiles"
      FCFLAGS="-O2 -pipe"
      FEATURES="assume-digests binpkg-logs config-protect-if-modified distlocks ebuild-locks fixlafiles news parallel-fetch parse-eapi-ebuild-head protect-owned sandbox sfperms strict unknown-features-warn unmerge-logs unmerge-orphans userfetch"
      FFLAGS="-O2 -pipe"
      GENTOO_MIRRORS="http://distfiles.gentoo.org"
      LANG="C"
      LDFLAGS="-Wl,-O1 -Wl,--as-needed"
      LINGUAS="en"
      MAKEOPTS="-j5"
      PKGDIR="/usr/portage/packages"
      PORTAGE_CONFIGROOT="/"
      PORTAGE_RSYNC_OPTS="--recursive --links --safe-links --perms --times --compress --force --whole-file --delete --stats --human-readable --timeout=180 --exclude=/distfiles --exclude=/local --exclude=/packages"
      PORTAGE_TMPDIR="/var/tmp"
      PORTDIR="/usr/portage"
      PORTDIR_OVERLAY=""
      SYNC="rsync://rsync.gentoo.org/gentoo-portage"
      USE="X a52 aac acl alsa amd64 apache2 berkdb bzip2 cdda cdr cleartype cli consolekit corefonts cracklib crypt css cups cxx dbus dri dts dvd dvdr exif ffmpeg flac fortran gd gdbm gnome gpm gtk iconv ipv6 jpeg lame lcms libnotify lzma mad mmx modules mp3 mpeg mudflap multilib nas ncurses nls nptl nsplugin ogg opengl openmp pam pcre png policykit pppd qt3support qt4 rar raw readline sdl session sse sse2 ssl svg taglib tcpd truetype type1 udev unicode v4l vcd vorbis xmp xorg zlib" ALSA_CARDS="ali5451 als4000 atiixp atiixp-modem bt87x ca0106 cmipci emu10k1x ens1370 ens1371 es1938 es1968 fm801 hda-intel intel8x0 intel8x0m maestro3 trident usb-audio via82xx via82xx-modem ymfpci" ALSA_PCM_PLUGINS="adpcm alaw asym copy dmix dshare dsnoop empty extplug file hooks iec958 ioplug ladspa lfloat linear meter mmap_emul mulaw multi null plug rate route share shm softvol" APACHE2_MODULES="actions alias auth_basic authn_alias authn_anon authn_dbm authn_default authn_file authz_dbm authz_default authz_groupfile authz_host authz_owner authz_user autoindex cache cgi cgid dav dav_fs dav_lock deflate dir disk_cache env expires ext_filter file_cache filter headers include info log_config logio mem_cache mime mime_magic negotiation rewrite setenvif speling status unique_id userdir usertrack vhost_alias" CALLIGRA_FEATURES="kexi words flow plan sheets stage tables krita karbon braindump" CAMERAS="ptp2" COLLECTD_PLUGINS="df interface irq load memory rrdtool swap syslog" ELIBC="glibc" GPSD_PROTOCOLS="ashtech aivdm earthmate evermore fv18 garmin garmintxt gpsclock itrax mtk3301 nmea ntrip navcom oceanserver oldstyle oncore rtcm104v2 rtcm104v3 sirf superstar2 timing tsip tripmate tnt ubx" INPUT_DEVICES="evdev synaptics" KERNEL="linux" LCD_DEVICES="bayrad cfontz cfontz633 glk hd44780 lb216 lcdm001 mtxorb ncurses text" LIBREOFFICE_EXTENSIONS="presenter-console presenter-minimizer" LINGUAS="en" PHP_TARGETS="php5-3" PYTHON_TARGETS="python3_2 python2_7" QEMU_SOFTMMU_TARGETS="i386 x86_64" QEMU_USER_TARGETS="i386 x86_64" RUBY_TARGETS="ruby18 ruby19" USERLAND="GNU" VIDEO_CARDS="radeon fglrx" XTABLES_ADDONS="quota2 psd pknock lscan length2 ipv4options ipset ipp2p iface geoip fuzzy condition tee tarpit sysrq steal rawnat logmark ipmark dhcpmac delude chaos account"
      Unset:  CPPFLAGS, CTARGET, EMERGE_DEFAULT_OPTS, INSTALL_MASK, LC_ALL, PORTAGE_BUNZIP2_COMMAND, PORTAGE_COMPRESS, PORTAGE_COMPRESS_FLAGS, PORTAGE_RSYNC_EXTRA_OPTS, USE_PYTHON
      linux toor # emerge -s libxcb
      Searching...
      [ Results for search key : libxcb ]
      [ Applications found : 1 ]
      *  x11-libs/libxcb
            Latest version available: 1.8.1
            Latest version installed: 1.8.1
            Size of files: 367 kB
            Homepage:      http://xcb.freedesktop.org/
            Description:   X C-language Bindings library
            License:       MIT
